Leak Testing Slantfin baseboards
Old 08-25-13, 06:15 AM
Received 15 Votes on 15 Posts
I am going to be takimg a couple baseboards out from the rafters in the garage to hopfully install them in the basement workshop. I believe these where removed by a previous owner for cosmetic reasons.
Any suggestions on how to leak test these before installing them?
Old 08-25-13, 06:21 AM
lawrosa's Avatar
Super Moderator
Received 10 Votes on 8 Posts
Just hook them up IMO... Dont know where they would leak from its copper....You would see a spot in the pipe if burst from freezing, otherwise the only place I would think would be your solder joint...
Old 08-25-13, 07:31 AM
I'm going to look them over as soon as I pull them down.
Just thought there would be a way to test them before connection them to the zone.
Old 08-25-13, 04:14 PM
Received 5 Votes on 5 Posts
These are copper pipe/aluminum fin-tube baseboards, right? Closely inspect them visually. If there were any leaks, they should show up as green discolorations.
Re-sweating old connections may be troublesome. Can you neaten up the old stubs or nipples with a tubing cutter?
Old 08-25-13, 06:27 PM
They are copper with aluminum fins.
I was planning on cutting them just after the fins and replacing the bleed valve ports and elbows so it's just the fins and copper within that is old.
