Boiler leak in coils
Old 10-05-13, 06:03 PM
Was cleaning the coils on my boiler, a peerless pinnacle PI-80, and a pin hole leak started.
There is no warranty because I installed and no pro did the cleaning.
Is there anything I can do to repair this? I was thinking maybe try silver soldering it.
Thanks, Buzz
Old 10-05-13, 06:19 PM
NJT's Avatar
NJT
NJT is offline
Received 2 Votes on 2 Posts
Oh man... that's bad news!
Isn't that stainless steel?
How do you know there's no warranty just because you installed... have you tried?
Not for nothin'... don't tell them you installed...
Old 10-05-13, 06:40 PM
Yes, it is stainless steal.
Manufacture date is 8-2004 on the boiler.
I guess I could try calling factory rep here in Minnesota on Monday and see what they have to say about it.
Have you heard of these coils spring leaks?
Is it that corrosive in there?
I was cleaning it with CLR and a small toothbrush sized brass brush.
Old 10-06-13, 02:32 PM
Up date
It worked for me, so far.
Today I silver soldered the coil. It went well.
Put it all back together, and fired it up.
Old 10-06-13, 02:48 PM
NJT's Avatar
NJT
NJT is offline
No, I haven't... I imagine it's corrosive but would hope that Peerless would see fit to use a high grade of stainless.
Sounds pretty labor intensive to me! Is that necessary? I wonder if the CLR is a good choice... that's an acid isn't it? Is that what Peerless recommends?
I didn't know you could solder stainless... I hope it holds for you!
Old 10-22-13, 08:36 PM
Silver solder still holding! No leak.
Hope it makes the winter.
