Pilot light problem on Burnham boiler (standing pilot light)
I have a 1983 Burnham gas boiler with a standing pilot + thermocouple.
The thermocouple seems to work. That is, I can stop depressing the knob in PILOT position, and the pilot stays lit--if the thermocouple has been heated for 40 seconds and is glowing. But then I notice a problem that may be cause for concern...
Now, I set the thermostat call for heat. The main burner fires up nicely. But if I turn the knob all the way to ON, the pilot light shuts off completely. I can only get it to re-light if I back away from the ON position just slightly.
1. My concern is that the pilot light will not be on the NEXT TIME that the house calls for heat--and that I could end up shooting the main gas into the home. (And, of course, if I force the pilot light to stay on, then I worry that it will leak gas if it blows out).
2. Here is another BIG concern. I just noticed that once the pilot is lit--I can set the knob to OFF, and the pilot stays on. Of course, it wasn't like this all winter. It was fully off. But now, I wonder if it was only off because of the thermocouple safety!
Please consider calling me on this one (phone number [removed] below). I am very tempted to shut down heat to the house and replace the entire pilot solenoid assembly. But hopefully, it is a minor issue and someone has seen this problem before (?)
--GarMont, [phone number removed, please read the forum posting rules - NJT moderator]
With all due respect, this sounds like something that a tech should be looking at.
When you turn the knob on the gas valve to OFF, it should go OFF, no questions asked.
In my opinion, replacing a gas valve is not something a DIYer without ADVANCED skills should attempt. Yeah, I know, it's a piece of cake... famous last words...
But, only you know your own limitations, so consider carefully what you want to attempt to do yourself.
