Riello burner motor issue?
Old 11-13-13, 07:27 PM
C
I had a new Peerless boiler installed 11/2012 with a Riello 40 F5 oil burner. I am beginning to have some issues with the fan binding up. The fan will bind up causing the burner not to fire and shut down. I have on multiple occasions unscrewed the fan cover and manually spun the fan. When doing so it allows the burner to fire properly and run. I spoke with a tech and he said the fan most likely came loose off the shaft. I proceeded to find the setscrew and attempted to tighten it. The screw wasn’t loose. I pulled on the fan to see if there was any movement maybe the motor bearing was going, there was no play in the shaft. I am hoping that you might have some suggestions on where I can go from here.
Do I need a new motor or am I missing something? How hard is it to change a motor? Any tips if i decide to tackle this issue?
Thanks in advance
Murray
Old 11-13-13, 08:34 PM
NJT's Avatar
NJT
NJT is offline
Received 7 Votes on 5 Posts
I think you should contact the installer and ask for warranty replacement. I know it's slightly over a year, but I'll bet that they'll cover it.
Old 11-13-13, 08:40 PM
Received 100 Votes on 94 Posts
I'm not sure but I think Riello has a 2 or 3 yr. warranty on parts.
