Ideal High temp low temp for a Biasi oil boiler?
Old 11-19-13, 05:36 PM
Hello I have a Biasi b10-4 boiler with a riello and a Bock indirect 40 gallon water heater and a hydrolevel aquastat 3250. the house is 2 heating zones and has one more circulator for the indirect, i wanted to know what is the ideal high and low temp settings for this oil boiler? for now i have the low off and the high at 180. the indirect is at 130. i usually keep the house at 69 during when were home and 65 when we are away.
Old 11-19-13, 06:10 PM
NJT's Avatar
NJT
NJT is offline
Received 2 Votes on 2 Posts
Sounds about right.
Do you have the "PRE-PURGE" turned on?
What do you have "ECONOMY" set at?
Is the home heating properly?
Old 11-19-13, 06:20 PM
the economy is set to 2 and the home is heating properly. only turns on when it needs to. whats the pre purge?
Old 11-19-13, 06:24 PM
boiler temp
the temp on the dial is at 158 but the boiler guage is at 120 deg. is this ok how come it doesnt go up higher then 120 but yet the hydrostat reads 158.
thank you for the reply by the way!! @ nJ trooper
Old 11-19-13, 06:36 PM
pre purge?
should i have the pre purge on?
Old 11-19-13, 06:39 PM
NJT's Avatar
NJT
NJT is offline
Is your system set up for multiple zones? if so, how many?
You have manual? It's in there (page 7)... if not, download here:
48-3250 - Hydrolevel 48-3250 - Model 3250 Fuel Smart Hydrostat
Sure, why wouldn't you want it?
Old 11-19-13, 06:41 PM
yes it is. i saw the page 7, thanks and ill will check but if its not on should i turn it on?
Old 11-19-13, 06:50 PM
NJT's Avatar
NJT
NJT is offline
When you say "on the dial..." do you mean the LED DISPLAY ?
My first impression is that the boiler gauge might be 'off'...
You may also have a defective temperature sensor for the control.
When in operation, does the AMBER "TARGET" LED light up?
Old 11-19-13, 07:02 PM
yes the led display, sorry.
as of now the pre purge was not turned on so i turned it on.
when in operation the amber light on target is not alluminated.
Old 11-19-13, 07:18 PM
update
so after the boiler was on and then the zone upstairs stopped calling for heat the boiler turned off and the "target amber light was on" the temp in the boiler guage was at 145 and the led temp was 151.
Old 11-19-13, 08:07 PM
NJT's Avatar
NJT
NJT is offline
Sounds OK to me.
The "target" temperature is that which the control calculates is needed to heat the home.
A difference between 145 and 151 is nothing to be concerned with.
Turning on pre-purge should save a couple bucks.
Old 11-19-13, 08:50 PM
Thanks for the input and guides
