Hydronic radiant floor heat install cost?
Im in the process of designing and getting bids on a new construction home and I'm thinking about radiant floor heating. Its in the Hartford Ct area and the house will be approximately 6000 square feet. 3 stories including a walk out basement that is included in the 6000 sf.
can anyone give me a ball park estimate on the cost per foot for installation? the basement level will be poured slab. and the rest traditional framing. flooring will be hardwoods and tile. no carpet due to allergies. fuel source will be propane, but also considering geothermal as I'm told it works well with radiant.
thanks.
thanks.
Well... if you are DOING IT YOURSELF, and I presume that's what you mean, since this is a 'do it yourself' forum, then it's the cost of materials which you can probably look up on the internet, plus whatever you bill your time to yourself at, divided by the square footage.
