Zone Valve Sufficient for Boiler Isolation?
Old 12-10-13, 08:47 AM
Is a Taco zone valve sufficient for boiler isolation when closed or is a ball valve neccesary as well?
Old 12-10-13, 08:49 AM
lawrosa's Avatar
Super Moderator
Received 19 Votes on 17 Posts
Yes.On the one side of the loop, but what about the other side?
Old 12-10-13, 09:08 AM
Thanks for the quick response. I will be putting a ball valve on the other side of the loop.
Old 12-10-13, 09:23 AM
lawrosa's Avatar
Super Moderator
What is it you are trying to do? possibly we can offer more insight?
Old 12-10-13, 10:14 AM
NJT's Avatar
NJT
NJT is offline
Received 2 Votes on 2 Posts
You mean isolation as in 'close for servicing to isolate system from boiler and not leak' ?
In that case I would NOT rely on a zone valve for that purpose.
Old 12-10-13, 10:45 AM
I'm adding an indirect to my current booiler. I would like to have the indirect zone fully isolated in case I need to replace the indirect in the future.
Old 12-10-13, 11:18 AM
NJT's Avatar
NJT
NJT is offline
Install full port ball valves on both supply and return of the new indirect zone.
It is usually recommended that ONE INCH piping be used for an indirect when supplied from an existing system and using a zone valve.
Old 12-10-13, 11:21 AM
Thanks. I already have the 1" pipe and zone valve all I need now is a few ball valves.
