rattling noise from hot water boiler
Old 12-11-13, 01:43 PM
Question rattling noise from hot water boiler
i have weil mclain 97+ hot water boiler with indirect hot water tank
has 3 zones with taco pumps - one for radiators, second one is for base boards ( extension - added ) and third one is for hot water ( indirect tank )
i see hear rattling noise and
appears to me this noise travels from one area of the home to another
can you please advise what is the cause ?
how serious it is ??
how to clear it ???
Old 12-11-13, 02:38 PM
lawrosa's Avatar
Super Moderator
Received 37 Votes on 32 Posts
Thats a fairly new boiler that was recently installed? Is it still under warranty from the installer? Most give a 5 yr warranty in our area......
If so I would call them in... That would be your best bet....
Old 12-11-13, 05:23 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
Are there 'check valves'... or 'flow checks' installed on the piping? They sometimes do rattle and you will hear it all through the piping.
Can you take some pictures of the system so we can better help pinpoint the problem?
Old 12-12-13, 12:52 PM
check valves or flow check
i am not sure if the system has check valves or flow check
but if you tell me where to look for it, i will or send you picture of that section
really appreciate your input
Old 12-12-13, 02:21 PM
NJT's Avatar
NJT
NJT is offline
All boilers are different... so I can't really tell you where to look.
Take pictures of everything and I'll see if I can spot them.
Old 12-18-13, 07:08 AM
pictures enclosed
see enclosed here with
two pictures
one is close up
your guidance will be appreciated
