GEEEZ Another Issue
Old 12-14-13, 06:01 AM
GEEEZ Another Issue
Well I posted a thread about T stats and I plan on replacing them. Now I think one of mine has an issue and if someone could confirm my suspicions I would feel a bit better. It is a cheap mechanical stat with a mercury switch. I am having an issue with short cycling. I have the cover off so I can see the mercury switch in action. The switch will tilt on and call for heat and the boiler will kick on and fire, within a minute or so I can physically watch the mercury switch tilt back to the off position and turn the boiler off. This will happen several times an hour. I think the heat anticipator is bad and causing the stat to turn off the boiler.
IIRC this same issue happened when we first built the house with the same type of stat. Does this make sense?
Old 12-14-13, 06:56 AM
Received 3 Votes on 3 Posts
You should be able to adjust the anticipator, move the lever towards longer.
Old 12-14-13, 06:59 AM
I moved it to the next setting with the same results. It was also working fine for the past 10 years and this just started happening a day or 2 ago.
Old 12-14-13, 08:53 AM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
Either anticipator has somehow took a dump, or something in the thermostat circuit is drawing too much current.
What is the thermostat 'driving'? Zone valve?
Old 12-14-13, 10:37 AM
Yes a Zone valve. I switched it with one from the bedroom and it seems to be working. I just got home with the new ones.
Old 12-14-13, 04:30 PM
Installed the 111B Honeywell and so far so good
