Burnham V8H4 vs Weil-McClain WTGO4 vs Peerless WBV/WV-04
Old 12-16-13, 05:17 AM
Since, my Burnham V74 leaked (cracked) I am in to replace the furnace. It is slow leak when furnace runs. Leak stops when furnace stops firing.
All three are 4-section boilers to heat 2800sqf space and has tankless coil for hot water supply. Cost to replace is about 6k to 7k. These are all from oil-supply company in this area.
I looked at 3-pass boilers. They are charging more for boiler and there is an external water tank required. So, this is more expensive option.
Any opinion? Appreciated.
Old 12-16-13, 08:41 AM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
For 2800 sq ft I would think that you would only need a THREE SECTION boiler... around 70K BTUH output. Is contractor quoting the 4 section without doing a heat loss estimate in order to properly size the replacement boiler?
Old 12-16-13, 03:46 PM
Since existing boiler is a 4-section, I preferred to stay with 4-section. No contractor ever offered the heat loss estimate to size the replacement. May be I can do the calculation if I know the steps or direction. With 3-section, what will I be saving? Cost of a new furnace? Less fuel consumption? Less maintenance?
How about heating the house if more than 1-zone demands? Or taking shower at the same time zone is demanding? Will 3-section be good enough to keep it up? Or furnace will have to run frequent and longer? Just a curious about these possibilities.
Old 12-16-13, 04:03 PM
Received 8 Votes on 8 Posts
Yes, you can and should do the heat-loss calc yourself. Get the Slant/Fin program (link in one of this forum's stickies).
Actually, if your boiler is sized correctly, it will run continuously at design ambient conditions. If you use the Slant/Fin program, a margin will be built in.
A boiler is unlike a horse. A boiler is designed to run full-bore indefinitely. It never gets tired or overheated. A horse would soon drop dead
Old 12-16-13, 04:34 PM
lawrosa's Avatar
Super Moderator
Received 37 Votes on 32 Posts
Did you try the stop leak to get you through the winter?
Heres your other post for reference...
http://www.doityourself.com/forum/bo...ml#post2201189
Here is the heat loss calc....
http://www.doityourself.com/forum/bo...alculator.html
Old 12-18-13, 05:59 AM
We had a sever cold December so far this year in north-east. Fortunately, warm temperature is coming, at least for time being. A slow leak is still there. It leaked about a cup of water in 24hr when outside temp is around 10 to 15f and that is because furnace runs more often. Leak stops soon after firing stops. I am not sure if I can make through the winter with this furnace. Its hairline crack for about an inch long.
As I mentioned in other post, putting liquid-sealer will require to modify the piping, something I can't do.
Old 12-18-13, 06:06 AM
lawrosa's Avatar
Super Moderator
I never saw pics of your system but you can add to possibly a boiler drain with a transfer pump....
Old 12-18-13, 07:00 AM
Here is the picture of boiler and plumbing. Thanks.
