Zone switch relay
Old 12-16-13, 07:24 PM
Zone switch relay
Hello all
Can I use a Honeywell RA 832A and Taco SR 501 with only one thermostat. And if so how should they be connected to each other?
Old 12-16-13, 07:36 PM
Received 21 Votes on 20 Posts
What are you trying to do AND why do you need both of them.
With only one zone why do you even need one.
Old 12-16-13, 07:52 PM
Radiant heat is not working properly. Have had two people out to look at it but they don't know why. Just trying to figure out problem I have two zones but original contractor didn't install second thermostat
Old 12-16-13, 08:10 PM
Are you saying you have 1 zone now and want to add a zone?
What do you have for a boiler control and are you currently using either of those relays.
What's it doing or not doing that it's not working properly.
Old 12-16-13, 08:16 PM
I have four zones two hot water baseboard two radiant aqua stat relay L8148E. Baseboard works fine radiant not heating properly air has been purged hot water at feed. Just trying to see what could be wrong. Thermostat set at 70 only getting to 60-62
Old 12-17-13, 09:33 AM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
Hi Jim,
Count me among the confused as to what exactly you are asking for.
First you mention one thermostat, then you say that you have TWO zones, then you say that you have FOUR zones.
Please try again... explain what exactly you are trying to accomplish.
Take pictures of your system, perhaps that will help us understand.
