Adding an Aqua Plus to Weil Mclain Ultra 155
Old 12-18-13, 06:18 PM
Hi, I've been browsing and searching a bit on the site. There seems to be a lot of smart folks here, so I'd appreciate some advice before I embark on my Christmas holiday project: adding an Aqua Plus indirect DWH to my existing Ultra 155.
I installed the boiler a couple of years ago, and as you can see from the unused valves just above the unit, always planned to install the water heater. Now as I'm finally getting around to it, I have a few (probably very) basic questions that I hope someone can help with:
1. Will a Aqua Plus 45 work with my system? I have a 40G direct fire now and it has been sufficient for all but the rarest occasions. I've seen this configuration elsewhere, but looking at the minimum btu/h in the Aqua Plus manual, I'm confused whether the 155 is sufficient.
2. I see there is a recommended clearance between the wall and heater of 12" --I'd rather not come that far out if it's really just a recommendation. Any concerns of getting closer, provided the piping is accessible?
I have a few more minor questions, but those are the biggies as I plan this out.
Thanks! Matt
Old 12-18-13, 06:54 PM
Received 2 Votes on 2 Posts
A 40 gallon indirect tank should be adequate. It is recommended that you install a mixing valve which will allow you to maintain a higher temperature in the tank and will also extend the capacity of the tank.
You should be made aware that there have been some issues with Aqua Plus thermostats:
http://www.doityourself.com/forum/bo...direct-wh.html
Old 12-18-13, 06:57 PM
Thanks for the heads-up Rockledge, would you recommend a different brand? I'm not committed to WM.
Old 12-18-13, 07:03 PM
lawrosa's Avatar
Super Moderator
Received 37 Votes on 32 Posts
Not a fan of the mclains...
IMO check out the Supor Stor.... The contender I consider throw aways... They can be had for about $700 bucks.. It should last 7-10 yrs.. Youll be ahead of the game in the long run IMO...
Check the specs and heat transfer....
SuperStor Contender Indirect Water Heater - Literature - HTP
Old 12-18-13, 07:14 PM
I can only recommend what I know, and installed for myself, which is a Triangle Tube Smart 40 (w/mixing valve).
I think Triangle Tube makes, or used to make, the indirect tanks for WM. But the thing is, the thermostat assembly on the TT Smart series tank is totally different from the problematic one found on the WM Aqua Plus series (on the Smart 40 there is an 'immersion well' that the t-stat probe drops down into from the top of the tank).
Old 12-18-13, 07:20 PM
lawrosa's Avatar
Super Moderator
Here is the spec.... IMO a 35 is plenty with fast recovery.... You need 8gpm to get that rating. Dont know what pump you have........
Name:  boiler indirect.jpg
Old 12-19-13, 09:28 AM
Thanks for the suggestion! Based on the WM manual and what I've read on the 35 contender, it looks like I'd be good with a Taco 0014 -- I'm calculating 13.9 head.
1 other basic question, should i reduce from 1 1/4" to the 3/4" the DHW accepts right at the heater or earlier in the piping (e.g. 1-2' before the connections)?
Old 12-19-13, 09:45 AM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
How did you cipher the 13.9' of head? Sounds high to me... but haven't looked at the specs, just a gut feeling... and the 0014 sounds like more of a pump than you need. I would think you could easily pump the indirect with a 007 ...
1-1/4 to the WH is probably overkill as well... I'm pretty sure you could get by just fine with 1" and yes, reduce right at the WH if necessary.
Old 12-19-13, 12:25 PM
Thanks for double checking, I just used the WM manual and the H = H1 + H2 + H3 equation. In manual, for a 9GPM flow rate, it has H1 = 6.2 and H2 = 2.1. The SuperStor lists 5.6 for H3. Is there a more accurate way to do that?
I also then used the pump curves in the manual and there was a big no man's land between the 12 and 14. According to the manual the 7 can can only handle 8ft head at 8GPM. On Taco's website, they recommend the 009, but again at the head i calculated above.
If I'm doing that wrong, I'd really appreciate being steered to a better calculation!
Thanks again, Matt
Old 12-19-13, 04:48 PM
NJT's Avatar
NJT
NJT is offline
Matt, can you post a link to the manuals you are looking at? I did find some similar info but want to look at the same thing you are looking at.
What I did see said that for your boiler you seemed to be right on with the 1-1/4 pipe and the 0014 pump...
It just seems like a lot to me... but that doesn't mean it's wrong! I mean, I'm heating my whole house with 1" ... I just can't see how one would need more than that for an indirect!
Old 12-19-13, 05:14 PM
lawrosa's Avatar
Super Moderator
Figure #1 here for the indirect.....5.62
http://www.htproducts.com/literature/lp-65.pdf
Old 12-19-13, 05:17 PM
lawrosa's Avatar
Super Moderator
Old 12-19-13, 05:27 PM
Yep, that's them --thanks lawrosa.
Old 12-19-13, 05:43 PM
lawrosa's Avatar
Super Moderator
Yeah I get a 0014.. They are about $280 bucks...
Old 12-19-13, 06:27 PM
Everyone always talks about an indirect tank. Any reason why a reverse indirect tank is not being considered? Cost maybe?
