no power on thermostat leads
Old 12-21-13, 02:03 PM
My thermostat suddenly stopped working. Thus no heat!
I bought a replacement Hon eywell T87K1007 but found there was no power across the leads on the old thermostat. On the boiler I have a Honeywell R845A relay controller.
Is there any way to test the controller?
Is there anything else to test?
Some sellers only have R845A 1030 Is this the same item?
Thank you
Old 12-21-13, 02:16 PM
Received 340 Votes on 318 Posts
Welcome to the forums.
That should be a basic two wire system between the R845A and the thermostat.
Remove the cover from the controller and short the two T connections or test for 24vac there.
If no 24vac there try carefully activating the relay manually. If the boiler fires then the transformer in the controller is shot.
Old 12-21-13, 03:05 PM
NJT's Avatar
NJT
NJT is offline
Received 2 Votes on 2 Posts
The 4 digit suffix usually doesn't mean anything... and good luck even trying to find out what it means because Honeywell literature is so durn confusing sometimes. The installation instructions rarely even mention the suffix. Yes, it will work... but before you do that...
In addition to testing as PJ has suggested, it would be wise to know if you've got 120VAC on terminals 1 and 2 of the R845 relay. If you don't have 120VAC on 1 and 2, you won't have 24 VAC on T T either.
For a few bucks less, the R8845U is a 'universal replacement' for the 845 and others...
R8845U1003 - Honeywell R8845U1003 - Universal Switching Relay w/ Internal Transformer
Old 12-22-13, 06:35 AM
thanks
Thank you so much.
A new relay is on its way and all I have to do is install it correctly
Old 12-22-13, 09:17 AM
NJT's Avatar
NJT
NJT is offline
Did you do the remainder of the testing and have concluded that the relay is definitely bad?
Please report your findings.
