Please help me to located the Bleeder valve ?
Old 01-03-14, 10:21 PM
I have a Weil McLain Furnace and I have 3 active zones; one of the zones is not giving heat. Please advise from my attachments where the valve to bleed the air of the line, Please.
Old 01-04-14, 09:18 AM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
You've shown us a picture of the actual oil burner only. You won't find any valves there to bleed the zones.
There are reasons other than an air block in the zone that will cause this problem.
Are your zones all operating on electric zone valves? or is there a pump for each zone?
What is the PRESSURE and TEMPERATURE gauge on the boiler reading?
Before you try bleeding, there are other things to check first.
