Zone not working/no heat demand when theromostat is on
Old 01-07-14, 08:59 AM
I'm having a problem with a zone in my house. When the thermostat is turned up there is no heat demand registering on my Tekmar Control and that zone is not getting any heat. I have a Burnham gas boiler. I have four zones in the house the other three are working fine. This one is on the 2nd floor of the house. I took the Honeywell thermostat off the wall, cleaned it, crossed the white and red wires and still no heat demand so I don't think it's the thermostat. I've manually opened the zone valve to get some heat in the upper part of my home. Any ideas what it could be? Thanks.
Old 01-07-14, 09:10 AM
You would have to see if you're getting 24 volts to your thermostat. This will cut your search in half.
Old 01-07-14, 09:13 AM
I know the thermostat is getting power because the AC is also hooked up to that thermostat and I'm able to turn that off/on.
Old 01-07-14, 09:22 AM
The cooling in your particular system uses a separate transformer so you can have one without the other. It's still not a definite that you have 24v there just by testing your cooling circuit.
Old 01-07-14, 09:26 AM
Oh. Ok. Unfortunately I don't have a voltage meter to check it. Any other ways to check it?
Old 01-07-14, 09:35 AM
Not really. Can you see the wiring from downstairs?
Old 01-07-14, 09:37 AM
Yes. It's a bit of a mess.
Old 01-07-14, 10:16 AM
Try to find where the wires from your tstat tie into the wiring downstairs. See if you can get some pics up as well. What tekmar do you have?
