American Standard Boiler G25DP Parts
Old 01-07-14, 09:21 AM
Hello. I have inherited a rental property that has 3 American Standard Boilers. One started making a horrific noise last week, then went away. Last evening it did it again. It makes a loud 'foghorn' noise that lasts about 8 seconds, repeats about 3-6 times, then stops when the boiler gets going. It has only done this on two instances. Visual inspection does not show any leaks or obvious malfunctions. The serial number off of the furnace is JBN-J6. I thought I would try and find part numbers for the pump and motor just in case Murphy's Law kicks in. Any help would be greatly appreciated.
Old 01-07-14, 09:28 AM
I've seen burners make that noise quite often. You may want to look into swapping those out for new units. A rental property is an investment that you should protect and keep well maintained. Boilers that are that age are bound to break down sooner than later. You don't want unhappy tenants. That could cost more in the long run than an actual replacement.
