No Heat in 1 Zone and Purged Air of System Feed pipe is Hot But Return is Cold
Old 02-12-14, 02:56 PM
Throw in some Sam Adams and I'll be there in a few hours!
You got it. But maybe we should wait for the spring time when its a wee bit warmer out.
Old 02-12-14, 05:40 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
What, you don't have a 55 gallon drum and a stack of firewood?
Everything still working good?
If you're like me you would have dissected the old pump for an autopsy... are you like me? If so, did you find anything really whack?
  #83
Old 02-19-14, 05:34 AM
I do have a stack of fire wood but I don't have the 55 gal drum. Haha
Everything is still working fine. And I do want to take apart the old pump. I will let you know what I find. Unfortunately have been very busy with work the past couple months and have a 5 month old so my spare time is niltch.
  #84
Old 11-18-14, 07:27 AM
NJ, I was poking around the site and remembered that I never posted about the failure mechanism of the circulator pump.
I took a good look at the bad pump and everything seemed to look normal except one of the large capacitors in the electrical circuit had a large bubble and burn. So this would be the reason the pump decided to give up. I suppose I could have just replaced that capacitor to repair the pump but the system is still running so I'm happy.
  #85
Old 11-18-14, 07:44 AM
NJT's Avatar
NJT
NJT is offline
That was probably the 'start capacitor'. If you still have the old pump you might consider getting a new cap for it ( $25 I think ) and keeping it on the shelf as a spare.
Thanks for the follow-up !
