Putting in new steam boiler and need advice
Old 01-28-14, 01:21 PM
Question Putting in new steam boiler and need advice
I have a cracked boiler and am replacing it soon. It has been down for a while so I installed an electric hot water heater. I would like to know weather I should bother getting the tankless water heater with the boiler or keep the water separate and on electric.
Old 01-28-14, 01:42 PM
I'm assuming you don't have gas. Correct? If you do have gas, the better choice would be a separate unit for your hot water.
Old 01-28-14, 01:46 PM
It's an oil fired burner.
Old 01-28-14, 01:49 PM
Tankless water heaters are terrible. Probably the worst form of getting hot water. If anything you can do an indirect water heater and run a loop off your steam boiler but you have to decide if oil is cheaper than electric. What about a heat pump water heater?
Old 01-28-14, 01:57 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
No... don't bother with the tankless if you already have an alternate. Tankless is 'thankless'.
Old 01-28-14, 02:01 PM
I haven't thought about indirect water storage but that sounds like an idea I will look into. I was told that the code up here is going to require them soon instead of the tankless. I will check the cost difference and maybe run the electric in the summer and the oil in the winter if it's worth it. I put in the electric so either one can be valved off at a time.
Old 01-28-14, 02:05 PM
Seems to be what I'm finding out I will look into an indirect water storage feed from the boiler.
Old 01-28-14, 02:06 PM
I've never been too fond of electric water heaters, but in some areas there isn't much choice.
Old 01-28-14, 03:44 PM
You can use a plate heat exchanger and use your boiler to heat the water in the electric water tank , works like an indirect with the coil on the outside .
Old 01-29-14, 07:33 PM
Thanks for all the info it came in very handy in my decision. This was my first time on but I can see it wont be my last.
