wiring a Honeywell AQ2504B4- repalcing two separate taco single zone controls
Old 02-24-14, 02:54 PM
I currently have two separate Taco single zone controls wired together for use in my two zone radiant heat system- (Trooper helped me with this) I want to add a third zone with its own actuator and thermostat- and got my hands on a new Honeywell AQ2504B4 4 zone controller for less than an additional Taco single zone control costs. I need some help wiring it up to my existing system. Here is what my wiring currently looks like:
Any suggestions?
Old 02-24-14, 03:48 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
Hi Monk, did you get the manual with it? For some reason I can't seem to locate it quickly via Google search, maybe it's a 'discontinued' model?
I thought I had a hard copy around here somewhere in my stacks of 5h1t but can't locate it either!
Never mind... I think Google just turned it up...
Old 02-24-14, 03:58 PM
NJT's Avatar
NJT
NJT is offline
I'm not certain, but have a feeling that you can't use a standard thermostat with these... you might have to use the AQ1000 thermostats...
What all did you get with your control? Which modules exactly?
Old 02-25-14, 06:52 AM
I don't have it in hand yet, however, here is a link to its replacement the AQ2504b4. http://s3.pexsupply.com/manuals/1351..._PROD_FILE.pdf
It looks straightforward enough- but I'd definitely like some guidance.
Old 02-26-14, 05:12 AM
NJT's Avatar
NJT
NJT is offline
When you get the unit we'll need to know which 'modules' you have.
