need help!!
Old 02-27-14, 07:41 AM
need help!!
i have forced hot air system in my condo with a direct vent hot water tank. my first question is when i run the heat, i get no hot water and also in the morning when i get up to take a shower. 2nd, i can't get my heat to get above certain temperatures. does this mean my hot water tank is going or do i have serious issues?? it will get warm enough but won't get above 65-70.
Old 02-27-14, 08:14 AM
Received 3 Votes on 3 Posts
Two separate systems or is the hot water tank going to a hydro coil to supply heat?
Old 02-27-14, 09:14 AM
i believe the hot water tank goes to a hydro coil to supply heat
Old 02-27-14, 12:13 PM
You probably don't have enough BTU's to cover the heat loss of the home. Tack on additional load for DHW and you're really out of heat. Can you provide some specs on the tank, coil and sq. ft. of the condo?
