Running two zones with a L8148E and a RA832A
Old 03-06-14, 12:40 PM
L
I bought an older house with a gas, baseboard, two thermostat, two circulator system.(L8148E is the aquastat, RA83A is the relay)
The 8148 is wired to the burner, thermostat 1, and circulator 1. The RA832 is wired to thermostat 2 and circulator 2. When Zone 1 is satisfied, burner turns off, regardless if Zone 2 is happy or not.
How can I connect these so that the burner turns on to satisfy Zone 1 or Zone 2? I'm having a hard time finding a wiring diagram for this setup, though I know the L8148E can be wired for multi zone operation.
Thanks in advance!
Old 03-06-14, 02:24 PM
Z
Received 13 Votes on 13 Posts
hi lessthan –
I am far far lessthan an expert, LOL (really just a rank newbie). I follow the guys here that know there stuff just to see what I can pick up. I’m sure they will be along soon.
I was looking at figure 8 on page 8 here:
http://s3.pexsupply.com/manuals/1287..._PROD_FILE.pdf
and I can’t see how a second pump can be hooked up using the 8148E. It just looks like anything you hook up to the 8148E will cause the burner to run – but also circulator 1 to run at the exact same time. Doesn’t seem like there is a way for the RA832A to use the 8148E to get the burner to run while it (the RA832A) gets circulator2 to run – without causing circulator 1 to run at the same time. And you can’t bypass the 8148E with the RA832A to control the burner and circulator 2 directly – can you LOL ?
The above is probably totally wrong? Probably the solution is simple and the pros will point to it.
Good luck!
Old 03-06-14, 02:30 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
Pretty much any aquastat can be wired for multi-zone, but whether or not you need external relays is the question.
In the case of the 8148, you DO need extra relays.
There's a couple ways you can go with this;
Install a SECOND RA832A (or equivalent) and wire the zone 1 pump and thermostat to it.
RA832A1066 - Honeywell RA832A1066 - 2 Zone 120V Switching Relay with Dpst switching
Run wires from the X X terminals on the old 832A to the X X terminals on the new 832A and then from there to the T T terminals of the aquastat.
In other words, the X X on both relays and the T T on the aquastat in parallel.
This setup will run the appropriate pump, and turn the boiler on when EITHER zone calls for heat.
OR
Purchase a Taco (or equivalent) zone switching panel and wire the thermostats and pumps to it, and the endswitch on the Taco panel to the T T terminals on the aquastat.
SR502-4 - Taco SR502-4 - 2 Zone Switching Relay
Basically, you can't keep Zone 1 on the 8148, it needs to be separated.
Decide which way you want to go and we'll help with the wiring.
Old 03-06-14, 02:43 PM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
Hello. Welcome.
What you need is another relay 832a.
Take the circ and t stat out of the 8148 and hook to new 832 relay.
Then run xx from both relays to TT in the 8148...
May be the cheapest...
Or get a taco control and do away with both relays.
Old 03-06-14, 02:45 PM
lawrosa's Avatar
Super Moderator
Sorry I dilly dallyed too much... Troop beat me to it...
[ yeah, great minds... I beat you THIS time, but you'll get me back, guaranteed! - NJT edit]
Old 03-06-14, 02:57 PM
Received 42 Votes on 40 Posts
Less,
To keep it simple, every pump needs it' own relay or a relay panel which is the same setup for multiple zones.
Lawrosa,
The race may be to the swift, but slow & steady gets the girl. And remember, you can't rush perfection.
Old 03-07-14, 02:27 PM
L
you guys are awesome. thank you. Now I need to decide if I want another relay box or the Taco to eliminate both. hmm....
Old 03-07-14, 02:36 PM
L
The taco looks great. Planning on finishing the basement, so a 3 zone looks appealing. Do any of you have any problems with the old model of the Taco 3 zone vs. the new Taco 3 zone? theres a new old stock taco for $50 on ebay vs the newer model for $130..
Old 03-07-14, 02:47 PM
NJT's Avatar
NJT
NJT is offline
Chris, if it truly is NEW old stock, for $50 I would grab it.
There was no problem with the older models, just that they were redesigned with more 'features'.
Old 03-07-14, 02:58 PM
L
You are a true gentlemen. Thank you for all the help!
Old 03-07-14, 03:39 PM
NJT's Avatar
NJT
NJT is offline
Thanks Chris...
If you need any help wiring it up, let us know!
Old 03-07-14, 03:44 PM
L
Thanks, I believe your answers before cleared that up. Don't worry, I'll need plenty more help. I think its an undersized boiler and will likely need help figuring out how big of a boiler to replace it with and which are the best brands.
Old 03-07-14, 04:41 PM
NJT's Avatar
NJT
NJT is offline
What's the make/model and BTU rating of the boiler?
How many square feet is the home?
To be UNDERsized would be truly unusual !
