American Standard boiler
Old 03-22-14, 11:03 AM
I have a American Standard Boiler approximately 54 years I'm looking for the gas valve
Boiler G25 DPG
Series: 6B J5
Input: 120,000
output: 96,000
Old 03-22-14, 12:01 PM
NJT's Avatar
NJT
NJT is offline
Have you looked inside the boiler, down by the burners?
Sorry, couldn't resist...
Seriously though, I doubt you'll find an exact replacement, but I'm sure you can find something that can be retro-fit.
Can you see any numbers on the gas valve itself?
What leads you to believe that the gas valve is bad? What are the symptoms?
Old 03-22-14, 01:26 PM
Rona,
V800A-1070 Honeywell gas valve. Pulled this off an old thread from someone who had the same boiler as yours.
Go to pex supply for the particulars.
Hope this helps.
This was used as a replacement GV on an American Standard G25.
This is also a 24v gas valve. Make sure you don't have a power pile system, which is different.
Good Luck,
Old 03-22-14, 04:01 PM
NJT's Avatar
NJT
NJT is offline
Highlighting this statement for obvious reasons...................................................
Old 03-26-14, 04:27 PM
American Standard boiler gas valve
NJ Trooper
The information I posted was for the boiler and now is going to be for the gas valve code 9-2-618 .has thermocouple is heat by the pilot light and is screw to the valve, also from the transformer has two wires with 24V they are attached to the gas valve on separe screws
Thank you for your help
Q.I don't understand went you said (power pile system)
Old 03-26-14, 05:06 PM
NJT's Avatar
NJT
NJT is offline
Hi Ron,
There are two basic types of gas valves:
MILLIVOLT
24 VOLT
The MILLIVOLT valve is 'powered' by a 'ThermoPile' which is similar to a 'ThermoCouple' but has a much higher output voltage. This type of valve does NOT need an external power supply to operate. There will be two wires going to it, but these wires do not supply power, only a 'switch' closure from the boiler control.
The 24 VOLT valve DOES require external power and the Thermocouple is only used to prove that there is a pilot flame lit before allowing the valve to open. The two wires from the boiler control carry 24VAC to the valve and are 'usually' marked as TH and TR .
Old 03-26-14, 05:07 PM
NJT's Avatar
NJT
NJT is offline
I can't find any reference to a gas valve with those numbers.
It might help if you could take clear pictures and post them.
