Gas Boiler circ pump not working
Old 03-26-14, 09:25 AM
my boiler has four zones and four pumps, one of the pumps (Bell & Gossett 100 series) stopped working. I noticed it blew its own fuse as well as the whole system breaker. I changed the fuse and reset the breaker and as soon as I adjusted the thermostat it blew both again. Does the entire pump need replaced?
Old 03-26-14, 09:30 AM
lawrosa's Avatar
Super Moderator
Received 10 Votes on 8 Posts
Hello and welcome......
Its possible its the pump but it may also be the control...
What type of controls do you have for the pumps? Such as a taco circ relay controller or individual relays?
Let us know...
Take some pics too...
Old 03-26-14, 09:48 AM
Who's Avatar
Who
Who is offline
Pump replacements are pretty simple... and there are pumps that are far more energy efficient than a Series 100, so the new pump can pay itself off in savings.
Old 03-26-14, 11:10 AM
photos
thanks, I break a lot of stuff, so I'm looking forward to it!
I believe they are individual relays (see pictures)
it looks like the pump would be fairly easy to replace, I was just hoping I didn't need to spend $300 right now
Old 03-26-14, 11:31 AM
lawrosa's Avatar
Super Moderator
A taco 007 should be a direct replacement...If it is the circ...
Possibly the coupler broke and is binding up the motor?
Do you have a multimeter and know how to use it?
You should check to see if you have 120v at the pump...
007-F5 - Taco 007-F5 - 007 Cast Iron Circulator, 1/25 HP
Old 03-26-14, 11:36 AM
I do not have a multimeter, but I can probably come up with one.
Is that a good model? I would like to replace it with a high quality/efficient part. Also, the flanges appear to be offset in that model. Will that create difficulties in installation since my current pumps are aligned flange to flange?
Old 03-26-14, 11:40 AM
lawrosa's Avatar
Super Moderator
No there is no offset...
Measure the distance between the two flanges on your existing pump...Tell us what that is... Just to make sure the spacing is good...
Those 100 series pumps you have are electric hogs.. The 007 will use less electric...
First off you need to test the non working pump for power. You may have another issue and it may not be the pump at all...
Old 03-26-14, 11:55 AM
NJT's Avatar
NJT
NJT is offline
Received 2 Votes on 2 Posts
Maybe 'offset' is the wrong word?
Perhaps 'flange rotation' is a better choice?
The 007 pump is available as 'standard', and with flanges rotated 90
Standard:
Rotated flange:
007-F5-8IFC - Taco 007-F5-8IFC - 007 Cast Iron Circulator with Integral Flow Check, 1/25 HP (Rotated Flange)
Old 03-26-14, 12:07 PM
Sounds like you may have a dead short, check to make sure the wire is connected properly inside the pump and that the wire clamp is not too tight causing a short.
Old 03-27-14, 12:18 AM
Who's Avatar
Who
Who is offline
I am a Grundfos 15-58 3 speed admirer... like lawrosa said that Series 100 is 1.75 amps or around 200 watts vs 55/70/85 watts for the Grundfos depending on speed - probably fine on lowest speed and it costs under $90.
My series 100 used to do cont circ all winter... replacing it, had less than a 2 year payoff in electrical savings.
