After hitting reset, old oil boiler runs....
Old 04-07-14, 05:11 AM
.....for a few minutes, then shuts off. I wait for a bit then hit reset again and it will start but shuts off quicker...maybe a minute after.
So I know it is getting oil, it fires, it starts to heat the water (the first reset after not running for hours) as I will have some warm water but then it quits before continuing to get through the heating pipes? Which is usually about 10 minutes of running.
Any advice would be appreciated! Thank you!
Old 04-07-14, 07:21 AM
NJT's Avatar
NJT
NJT is offline
Received 4 Votes on 3 Posts
When was the last time the system was serviced? Oil burners require ANNUAL service.
Old 04-07-14, 05:27 PM
Received 85 Votes on 79 Posts
S,
Sight unseen since it lights and runs you may a clogged filter or pump screen. If not running for a while the oil has a chance to fill the line and pump but once it starts the oil flow is obstructed and taking to long to get to the nozzle.
It could be the pump also but maybe just servicing the burner and changing your oil filter and pump screen and possibly blowing out the oil line would do it.
Good Luck,
