help with honeywell zone valve wiring!!!!
Old 04-16-14, 08:44 AM
Exclamation help with honeywell zone valve wiring!!!!
I am trying to replace honeywell zone valve head for V8043E. Unfortunately, although I purchased the same model twounits do not look 100% identical.
There are two yellow wires (one connected to orange one) and I have no problem with these as they do look identical.
On the other hand, there are two red wires. One old unit they came from front/back from the same spot of head. In the new unit, wires come a quarter inch apart (left right).
So I can put yellow wires exactly where they were in the old unit but not red ones. Does it matter if I mix up one red wire with another one?
How can I figure out which red one goes to which? As far as I can tell, there's no mark/letters where these red wires are coming from (in the zone valve head)
Thank you!
Old 04-16-14, 10:01 AM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
The new valve wires exactly the same way as the old valve.
There is no issue with the 'polarity' of either the red or the yellow...
