Heat is not working - help!!! Baby in the house
I'm not what happened but my heat went out Sunday night after working all day. Its getting colder now and I'm not sure what to do. The piolt light appears to be on. Help!!
I presume this is a gas-fired hot-water boiler? If so, there is typically a 24-V control circuit that opens the gas valve when there is a heat call. Best to troubleshoot that circuit with a multimeter. If that is beyond your skill set, then call a service person.
how would i go about doing this?
Then, you would need to understand what the various components are inside the boiler that we would ask you to measure the voltage on.
From what I can gather from the posts so far, you haven't the time to learn what you would need to learn in order to help us help you, therefore, call a heating technician.
Without knowing what's wrong, we can't guess at the price...
In your situation, either call a service person or plug in a portable electric heater in the baby's room. Tomorrow is May 1.
