water heater pilot light
Old 07-30-14, 06:25 AM
When I release the pilot button, I lose all flame.
Old 07-30-14, 06:52 AM
Make and model number of the unit?
You probably need a new thermocoupler.
Old 07-30-14, 04:24 PM
Agree with Tom. Most repairmen would just replace the thermocouple - a few bucks at a hardware store, assuming yours is the usual standard type. Get one of sufficient length. A simple DIY project, or call a serviceman, and pay $100 or so. Thermocouples seem to last only about 10 years.
If it isn't the thermocouple, then the only thing I can think of is the fuel valve, which is a horse of a different color.
Old 07-30-14, 04:36 PM
lawrosa's Avatar
Super Moderator
FYI you cant just replace the T couple by itself if its a newer heater. It comes as an assembly. This is because some have safety features built into them such as fusible links and/or thermal switches built into the t couple..
You can be creating a possible saftey hazard try to intall a regular t couple and the unit does not call for it..
Post make and model please as was asked previously..
Old 07-30-14, 04:41 PM
lawrosa's Avatar
Super Moderator
Example.. Here is an AO smith pilot assembly.. Igniter, pilot tube, a t couple all in one.. This T couple has a resettable thermal switch that will shut the gas down in case of overheat condition...
You cannot replace with an off the shelf t couple.
