Boiler Mate WH7L noise
Old 08-21-14, 07:16 AM
Helping a friend on this one.
A Boiler Mate WH7L makes a noise sounding like something between a plucked guitar string and a woodworking shop planer. First it's really loud and then it resonantingly tapers to silence over a minute or two and repeats. Happens several times a day regardless of water use.
What could it be?
Old 08-21-14, 07:48 AM
lawrosa's Avatar
Super Moderator
Sounds like a flow control. If it has one open it up all the way and see if the sound stops.. Since no heat is being used you can leave it open for test purposed..
Old 08-21-14, 08:16 AM
Don't think there is one.
Name:  P1070986 (Medium).jpg
I don't think there is one. Can post this photo with more resolution but don't know how.
<a href="http://************?ref=x25iyc" target="_blank"><img src="http://i58.************/x25iyc.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Thanks.
Old 08-27-14, 02:15 PM
I haven't opened the panels on the blue tank.
Is there anything within it, specifically the lower third, can can present a resonating sound through the nearby pipes?
Old 08-27-14, 04:29 PM
NJT's Avatar
NJT
NJT is offline
Can't use tinypic on this forum for some reason.
Use photobucket.com instead.
Could be worse... at least it doesn't sound like a banjo string and a radial arm saw!
I can't think of anything inside that bottom section that would cause this, all that's in there is the piping in and out of the tank.
When was the last time the tank was flushed?
Old 08-27-14, 04:34 PM
NJT's Avatar
NJT
NJT is offline
Ya know... stranger things have happened, but if it were me I would not rule out a defective leaking toilet valve.
I had one years ago that HOWLED like a banshee ... I mean LOUD!!!! resonated through the pipes in the entire house... it occurred as the toilet tank was about 2/3 full until it filled. When that toilet valve leaked a bit and the toilet refilled itself every couple hours, it did the same thing. I finally got off my butt and fixed the darn thing...
I think the note was either a C-flat, or an E-sharp.
Old 08-27-14, 04:43 PM
lawrosa's Avatar
Super Moderator
Could it be a zone valve trying to open and the spring is twanging while the gear is stripped? And it just keeps trying to open, then clicks closed, then open, then closed....etc..
But the boiler would no fire with end switch..????
Think I saw one do that once many moons ago....
Old 09-02-14, 05:27 AM
Only if there's one within the tank. I've never opened it, but for sure, the sound is originating from the lower third of the tank.
Was told the local plumber, a handyman of sorts, in the rural area where the tank is only scratched his head looking into the noise. Should it be significant, this is on very hard well water and at 8,600 feet.
Old 09-02-14, 05:55 AM
lawrosa's Avatar
Super Moderator
I have to look up the specs on the boilermate as I forgot if it has a jacket or coil... If a coil you can try cleaning it...
