SuperStor SSC35 Indirect HWH Circulator Location and 1" Coil Piping
Old 09-01-14, 04:17 PM
SSC35 drawings show the circulator mounted on the boiler supply hot side.
My current Bock indirect has the circulator mounted on the same side as the the expansion tank and air scoop, the return side. I'd like your opinion of the consequences of keeping the SSC35 circulator on the return side instead of the supply side?
The SSC35 calls for 1" pipe for the coil run. I can't easily convert from my present 3/4"coil piping setup. So I'd like to use the 1" coil piping up to the 3/4" Grunfos 15-42fr circulator and continue the 1" pipe after the circulator to the 3/4" in and out of the boiler. I'd like to know if this an acceptable approach?
Boiler is Weil McLain GV3 series 2 at about 108000 btu.
Old 09-06-14, 04:02 PM
It doesn't make a lot of difference. I've piped them both ways. The 3/4 might take an extra 30 seconds to heat up but it's not worth changing in my opinion.
It doesn't matter about the side it's on either. Grundfos pumps are a little better at pushing than pulling but it's a short loop. It'll be OK.
Old 09-06-14, 04:59 PM
lawrosa's Avatar
Super Moderator
Received 14 Votes on 12 Posts
Well I have to read the specs, but the ssc I believe needs 40K btu min for full output..
So you have a 108K btu boiler. Then with reduced piping??? IDK.. May be a wash but I would need to dive in and do all the calculations...
Whats there now? Do you run out of hot water?
Old 09-09-14, 11:00 AM
Correction: Boiler is GV4 series 3 with 88000 btu out.
Dburr9 I think the flow rate for 3/4 inch copper is 4.9gpm. That's much less than 1". May affect recovery time. The more I think about it the more important that is to me. I'd like 25 minute or so recovery.
Lawrosa, Currently 30gal Bock CT30 Indirect. It's coil setup is made for 3/4". It does an OK job with the hot water considering there are 4 people here.
Last Nov many here on the board chimed in to help address a leaking boiler PRV. (Thanks All) At that time the Bock was thought to possibly have a pinhole. Lawrosa suggested the contender to replace it. As it turned out there was no pinhole. But, I got a deal on a contender recently I could not pass up and I'd like to replace the 20 yr old Bock.
New Subject... I recently serviced the expansion tank. Then did boiler cold fill to 14psi @ 80F. I left it that way with boiler off and came back to it 8hrs latter. Gauge still read 14psi. Started the boiler and pressure went to 20psi at 180F. Now when the boiler is cold or hot the pressure stay at 19/20psi. I never noticed before but I thought when the boiler cools the pressure should go back to 14psi. What think? Thanks guys. (Boiler PSi Gauge Verified With Test Gauge)
Old 09-09-14, 02:33 PM
NJT's Avatar
NJT
NJT is offline
Received 2 Votes on 2 Posts
If the gauge doesn't change from cold to hot, there's something wrong with the gauge.
Flick it with your finger... tap tap ... bet it moves!
Old 09-09-14, 04:31 PM
NJtrooper, I've tapped the gauge and nothing changes. I've also connected a test gauge and it confirms the 20psi. If I cold fill with PRV to 14psi the test gauge confirms the 14psi.
Thanks for chiming in on this.
Old 09-10-14, 04:10 PM
NJT's Avatar
NJT
NJT is offline
That's weird Doc.
The pressure HAS TO change from cold to hot! It can't not! That would be breaking physical laws.
Tell me where your expansion tank is piped into the system... and where the supply water is piped in also... relative to the pump location.
Better yet, are there pics of your system posted in another thread? Can you point to them, or if not, can you post some so we can see how it's piped?
Old 09-10-14, 06:11 PM
Street fill valve at street pressure to BFP to PRV .
2014-09-10_2106 - Docfletcher's library
2014-09-10_2104 - Docfletcher's library
2014-09-10_2103 - Docfletcher's library
2014-09-10_2044 - Docfletcher's library
http://screencast.com/t/DGKAWDxB7Zex
http://screencast.com/t/gEEALMsE
The red handle valve on the right in the last photo is where I'm attaching the test gauge to.
It might change by 1psi but that's about it.
