Combining Boiler and central air on one thermostat
Old 09-12-14, 02:47 PM
I have a boiler and central air that are controlled by different thermostats. I have already run the wire to combine the two but need to know what wires to put where. I am going to use a Honeywell TH1160D thermostat.
Here is the current wiring for the AC
and here is the wiring for the heat:
I think that I need to wire it as follows:
- remove the R/Rc jumper
- connect the red wire from the heat to the R terminal
- connect the white wire from the heat to the W terminal
- connect the red wire from the AC to the Rc terminal
- connect the blue wire from the AC to the Y terminal
- connect the green wire from the AC to the G terminal
The thing that is throwing me off is the white wire that is connected on the AC t-stat.
Can someone help as to how I should wire this?
Thanks,
Andy
Old 09-12-14, 04:24 PM
NJT's Avatar
NJT
NJT is offline
Received 2 Votes on 2 Posts
On the A/C wiring, where is that WHITE wire going? It's typically not used for A/C. Is it just hanging inside the A/C unit?
Old 09-12-14, 05:58 PM
OK I took a look at the air handler and it does seem that the whit is not used. I have connected as I listed and left the white (AC) wire disconnected. Everything seems to be working now.
Thank You for your help,
Andy
