Pressure/Temp gauge stuck
Old 09-15-14, 07:36 AM
Question Pressure/Temp gauge stuck
My Pressure/Temp gauge doesn't work and needs to be replace, but it is hard to take out. Rather than taking a chance on breaking it off. I figure I can just leave it where it is and add a new gauge.
I was thinking to remove the 1" elbow where the hot supply riser and the supply manifold join. And replace it with a 1 x 1 x 1/2" Tee with a terminate on one end and add a female fitting to the top of the tee so I can thread in the gauge there. Is that a good location and is this a good idea?
Old 09-15-14, 08:06 AM
Received 5 Votes on 5 Posts
That would be OK for pressure measurement. But, personally, I think the temperature function should measure the temp inside the boiler itself.
Old 09-18-14, 06:54 PM
I have the exact same issue. How so I safely remove this thing?
Did you manage to take yours off?
Old 09-18-14, 08:18 PM
9/16s wrench. They're tough to get out but they'll come out. The problem with a tee is that there is a shift behind the gage that needs room. It also needs to be inside of the boiler not in a pipe.
Old 09-19-14, 04:08 PM
thank you very much I will give it a try tomorrow.
Old 09-19-14, 04:19 PM
Too-Late advice
If you leave a gauge installed for a long time, particularly if pipe dope of Teflon tape wasn't applied to the threads, they can get stuck. Best to replace the gauge every 5-10 years, because they can go bad anyway. Alternatively, every few years, loosen the gauge a fraction of a turn and retighten.
Old 09-20-14, 12:33 PM
dburr - 9/16 worked!
thanks for giving me the confidence to lean on it a bit.
I was scared that I would break something off if I pulled too hard.
