Honeywell S9361a ODR
Old 09-18-14, 12:19 PM
I have a Crown Aruba 4 boiler that was installed last year. It uses a Honeywell S9361a integrated boiler control. While looking over Honeywell's website I found that they have an ODR module that they say works with S93 boiler controls, link below. I picked one up and installed it but no extended parameters come up and it does not change the high limit. Is it possible that I have an older controller with older firmware that does not support the ODR? I talked with a Crown tech guy and he was sure I needed their OC panel, don't know that Honeywell part number. I also tried to talk with Honeywell but that lead no where because I'm a home owner.
https://customer.honeywell.com/en-US...d=W8735S1000/U
Old 09-18-14, 03:59 PM
NJT's Avatar
NJT
NJT is offline
Knowing how badly Honeywell mismanages their firmware control I would say that's a distinct probability.
Just looking over the 2011 version of the install sheet for the 9361 and see no mention of the ODR module.
How old is your system?
Old 09-18-14, 04:04 PM
NJT's Avatar
NJT
NJT is offline
That HW webpage you linked to says this:
Compatible with Outdoor Reset-Ready L7224/L7248 Aquastat®s, S93 Integrated Boiler Controls,
I think the keywords here are "Outdoor Reset-Ready..."
I do know for a fact that the module will NOT work with older 7224s, so there are absolutely revisions that are NOT "reset-ready". I have not found a way to query the controls to determine a 'revision number', nor have I ever seen any documentation from HW that says what will work with what revision, etc.
You might have the paddle, but not the canoe.
Old 09-18-14, 04:18 PM
NJT's Avatar
NJT
NJT is offline
This revision of the manual mentions the outdoor reset modules:
https://customer.honeywell.com/resou...0s/66-1203.pdf
But all previous ones do not.
So, I suspect that they 'cut in' the new firmware with models produced mid-late 2012.
Old 09-18-14, 05:16 PM
I just bought the house and the previous owner had it installed last August IIRC, I have the paperwork. Looking at the boiler sticker it does have CSA 2010 so looks like I either need a new controller or forget the ODR. Kinda stinks that it was three years old at install. Do you think the ODR is worth it?
