Heatmaker II trouble, burning up my transformer
Old 09-22-14, 03:28 AM
I have a Heatmaker II, about 20 years old, I have had to learn how to replace igniters, pressure switch, and many other things, generally I have been happy with this boiler. My problem is that the unit has now started to cause the transformer to fail. Has anyone had such a problem, what might cause the problem, and how to fix it? Thanks
Old 09-22-14, 08:49 AM
Welcome to the forums.
Transformers fail when the wiring shorts out or they are overloaded.
What size was the transformer that failed ? It will be stamped on it in va.
How many zone valves do you have and are they attached to the same transformer ?
Old 09-22-14, 10:14 AM
I would suggest putting an automotive in line 5 amp fuse to protect the transformer .
Old 09-22-14, 11:12 AM
Protecting a transformer with a fuse is a great idea but the transformer can still fail with a short and a 5A fuse inline. I'd recommend a 4A fuse or even 3A if the load is light.
Old 09-22-14, 11:24 AM
I have always used a 5 amp , but the smallest fuse that will carry the load makes sense .
Old 09-22-14, 12:55 PM
I usually use a 3 amp fuse with no issue.
Old 09-22-14, 02:07 PM
I will try a 3 amp on the next install.
