Both my zones aren't working.
Old 10-05-14, 05:12 PM
How is everyone? 1st post. Long time lurker. Lots of info on this forum. I've been searching the web and this site for some answers about my situation. I've gotten a few, but I still need help and advice.
I have a Peerless Boiler, along with a Honeywell L8148E aquastat, a TACO SR502, and a Tekmar 260 DHW. Boiler will not fire up when I switch on thermostats.
I have 120 vAC at the L terminals of the aquastat. When I jump the TV and V on the Aquastat, the relay clicks but boiler does not fire up. It does fire up however when hot water is needed.
I did, in a moment of desperation swap out the SR502 for the newer sr502-4. As I didnt have 120 VAC at the input of the old unit. Unfortunately, when I turned power back on, the sr502-4's relays clicked on and off and i was getting wild voltage swings(below 120 vac) at the input. I have since put back the original sr502. Problem still remains.
Thanks in advance for any help and advice.
Old 10-06-14, 06:33 AM
Can someone lead me in the right direction?
Old 10-06-14, 07:48 AM
NJT's Avatar
NJT
NJT is offline
Hi Johnny, I hope that someone can... but you must realize that we are all volunteers here and answer when we have the time to do so.
Right now I do not have the time to do so... If nobody has replied by this evening I will see if I can make sense of what you have written.
Old 10-06-14, 07:51 AM
NJT's Avatar
NJT
NJT is offline
OK, I lied... I do have a little bit of time... and want to ask this:
DHW? did you mean " ODR " ? The 260 is not a 'DHW' device... it is an ODR (OutDoor Reset).
Are you sure that the 260 is not in WWSD (Warm Weather Shut Down) mode?
Old 10-06-14, 09:14 AM
Thanks for responding. How do I check for wwsd?
Old 10-06-14, 09:22 AM
One thing I neglected to mention in my original post was that I I shut the boiler down and drained the boiler. I had repair a leak in zone one. My apologies for omiting that.
Old 10-06-14, 12:42 PM
NJT's Avatar
NJT
NJT is offline
To me, this sounds like an issue with a wiring error.
I believe that there will be an icon on the screen of the 260 that indicates WWSD.
drained the boiler
Do you by chance have a LWCO (Low Water Cut Off) on your boiler? If you did not get all of the air out it's possible this could cause an issue.
