big issue or not
Old 10-09-14, 08:21 AM
big issue or not
I am adding zones and found there are lots of rust on one of the connections with air scoop. The system is 5 yrs old.
This is the connection issue or the air scoop issue?
I didn't see any wet. I may happened years ago?
What I should do? leave it as is? reconnect it? replace the air scoop?
I am now working on that area. It will be a good opportunity to do something on it if it is necessary.
Please have a look at the pictures.
thanks
Old 10-09-14, 09:01 AM
lawrosa's Avatar
Super Moderator
Received 20 Votes on 18 Posts
Well if its not leaking leave it would be my opinion...
But its a lot of work to fix if you chose this route. If you are going to go to all that trouble replace with a better scrubber type air removal system....
Old 10-12-14, 11:04 AM
How about put a union between the new added two zones and the existing zone in case it gets worse? Please refer to this thread to see what I mean the new two zones. I am adding two new zones to the right of the existing zone after the air scoop.
With the union, only one zone will be affected if I have to reconnect or replace the air scoop. But i am also worrying about if the union is good or not for place like this.
