Pressure Reducing Valve - Lock Nut
Old 10-21-14, 07:05 AM
E
Hello all,
I have a B&G pressure reducing valve on my system - the kind where you need to loosen the lock nut before you adjust the screw to adjust pressure. Just my luck, I went to adjust yesterday and the lock nut is fairly stripped. I have tried oiling it up but cannot get it to budge whatsoever. Can I just (carefully) cut off the old nut and just throw on a new 13mm lock nut to replace?
Here's a pic:
http://i.imgur.com/AEUrHlK.jpg
Old 10-21-14, 08:45 AM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Did you try vise grips??
A small monkey wrench will work too..
[ATTACH=CONFIG]40452[/ATTACH]
[ATTACH=CONFIG]40453[/ATTACH]
Old 10-22-14, 05:39 AM
E
vise grips did the trick (a little oil and heat didn't hurt either). thanks!
Old 10-22-14, 12:45 PM
lawrosa's Avatar
Super Moderator
Glad it worked out...
I guess there is an issue on why you are adjusting the pressure???
