Make your own Boiler Neutralizer Assembly
I know this is a really old thread,
http://www.doityourself.com/forum/bo...-assembly.html
but wondered if you still have your photos. They are no longer on the ImageShack website. Can you repost the pictures or private message them to me ?
Thanks for the replies. I went ahead and PM'd Gas2Oil. I know there are neutralizers out there, but I did not want to run to the floor drain as I think I would trip on it going to the house vacuum! :-)
As an option, I have the "drip" pipe for the floor drain stuck out through the wall and wanted to run the condensate fluid into that wall pipe so that the condensate drain pipe stays at the wall and not on the floor.
I am seriously thinking of using a 5 gallon bucket with appropriate agents and pump to neutralize the condensate (e.g. lime or marble). I would poke a barb near the top and run into my wall drain. And I could keep the entire bucket near the boiler (between boiler and indirect water tank - out of the way).
I only have a height difference between the floor standing boiler drain and the wall drain of about 5 or 6 inches. This doesn't allow much room for "gravity" feed into a neutralizer and then into my wall drain. Thinking about what might work best, so looking at anything I can find to make something work.
