Taco valve not working properly
Old 10-26-14, 08:56 AM
Hello, I have baseboard heating with a 3 zone taco valve which I'm receiving continuous heat in the manual position only. The automatic position is not triggering the thermostat. Will changing the taco head solve my problem and can I DIY. Thanks
Old 10-26-14, 09:29 AM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
You mean ONE of the THREE zones is malfunctioning? The other two are working properly?
Do you have a multimeter and know how to use it?
Old 10-26-14, 11:00 AM
Yes the thermostat is not controlling the heat. I only have one taco valve zone Supplying heat to my condo, however the only way I can get heat is when I push the lever on the taco zone valve in the continuos mode ( manual)
Old 10-26-14, 11:30 AM
NJT's Avatar
NJT
NJT is offline
OK, you're confusing me... sorry...
You have only ONE Taco zone valve, and I think what you meant at first is that it is a THREE WAY valve.
In other words, there are three pipes connected to that valve.
Is that correct? I think it is what you mean...
Since you are in a condo, are the repairs to the heat YOUR responsibility? or do you pay maintenance fees to cover the cost of repairs? Check your contract, why should you have to pay for it if it's included in the maintenance contract?
If you are responsible for this, yes, it is easy to change the power head of a Taco valve.
Read this:
http://www.taco-hvac.com/uploads/Fil...ry/102-076.pdf
Tell me the exact model of the valve and I'll let you know what to buy.
Old 10-26-14, 01:12 PM
Yes in unfortunately I am responsible for maintaining my heat inside my unit. The taco zone valve model is 571-2. Thank you for helping me
Old 10-26-14, 02:22 PM
NJT's Avatar
NJT
NJT is offline
You need this power head:
555-050RP - Taco 555-050RP - Zone Valve Power Head (Series 570)
You're welcome, and good luck!
Old 10-26-14, 04:37 PM
If you have a Lowes near you they have them there for $76 or at least my local ones do. 5 minute job.
Old 10-26-14, 04:52 PM
G
Received 28 Upvotes on 27 Posts
Lowes have them there for $76
This would be an advantage for living in the Northeast. In the Midwest, no big-box stores stock components for hot-water heating - not even a circulator pump, an expansion tank, or an air eliminator. For many, many decades, once natural gas became readily available, all new houses were built with forced air heat. I'm one of the last of the Mohicans, along with owners of legacy, older houses, once fired with coal.
Maybe my life be would be simpler if I moved to the Northeast? (Rhetorical question, don't answer that.)
Old 10-26-14, 05:08 PM
NJT's Avatar
NJT
NJT is offline
Come on over! First round is on me!
Old 10-26-14, 05:34 PM
G
Thanks, that is a very generous and tempting offer. But, I regret to say that I have gone from beer to vodka martinis. Sorry, but thanks anyway. I'll stay here.
Old 10-26-14, 08:20 PM
NJT's Avatar
NJT
NJT is offline
I like a nice Martini from time to time, I'll come to you! Cheers!
Old 10-27-14, 07:24 PM
G
OK, move to the Midwest, I'll pour you a dry martini (olive or twist, up or on the rocks?). But then, you will have some major problems to confront. Limited boiler replacement parts, except over the internet. And then, what to do with the big $ between what you sell your house for in New Jersey, and a replacement abode here. And what to do with the savings from using natural gas?
Old 10-27-14, 07:32 PM
NJT's Avatar
NJT
NJT is offline
More money to buy beer to wash the taste of the Martini's out of my mouth! ha ha ha
But then, I bet you don't have a big supply of Sam Adams at your local Spirits Unlimited, do you?
