not enough hot water
i have a weil mclain wtgo-4 boiler... my hot water supply is very little and the water seems to be colder than usual. I used to have unlimited hot water, now only 5 min or so. all started happening after i had it serviced/cleaned. Just replaced igniter as well. Its 18 yrs old. What should i check next?
First off, let's make sure that you are not blaming the wrong appliance...
Your boiler has an internal "Thankless Coil" that produces your domestic hot water?
Or, do you have a separate water heater tank?
