Radiant System Design
Old 11-12-14, 06:23 AM
N
I'm renovating a house in NJ. I have installed pex and extruded heat transfer plates under the sub-floor and pex in the concrete basement floors.
I'm at the point now where I need to design the system in order to complete it. I realize the design should have been done first.
I'm seeking someone with the proper expertise to assist in the design.
[Against the forum rules to solicit contractors on the forum, please read rules... NJ Trooper edited]
Mike
Old 11-12-14, 08:20 AM
F
Received 36 Votes on 28 Posts
If I remember the quotation correctly, "Radiant is easy to do, doing it correctly is not."
I hope that you used oxygen barrier PEX and not regular PEX for your loops. I also hope you properly insulated below the slab and added a thermal break between the slab and the footings.
