boiler size
Old 11-17-14, 04:51 AM
L
boiler size
Hi, a long time ago I replaced the boiler in my mom's old house. The old boiler was a 400,000 BTU monster. I used a heat-loss program which said we needed about a 300,000 BTU boiler. We installed two 150,000 BTU boilers, and quickly discovered that most of the time only one of them was needed to comfortably heat the house. (Only needed the 2nd one when it was below 10F outside.)
Now one of them has died, and I'm thinking of just installing one big boiler. So what size do you think I should go with? Seems silly to me to install a 300,000. However I should add that the old boiler did run most of the time in cold weather.
Thanks,
Laz
Old 11-17-14, 05:00 AM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
How did it die?
What is the sq ft of homes?
What type of heat emitters in the home. Cast iron rads, baseboard?
Is this HW or steam...
Old 11-17-14, 06:30 AM
L
The boiler started leaking steam.
The house is about 6,000 square feet.
Hot water with mainly cast iron radiators.
Thanks.
Old 11-17-14, 04:17 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
Exactly where is this 'steam' coming from?
If you need 300K BTUH to heat a 6000 sq ft home there are certainly improvements to be made in the heat loss of the home. That's FIFTY BTUH / square foot, and that's a lot of heat loss.
Insulation and air sealing is fuel that you only pay for ONCE. It's the first thing that should be done.
If you can cut the heat loss down, you can run a smaller boiler and save money year after year on fuel.
That aside...
Of course, because most of the time it's not super cold outside and the heat loss is less.
If for some odd reason you do need 300K BTUH to heat the place, you would do well to continue to use two boilers and control them so that they are staged.
