Vxt-24
Old 11-22-14, 09:11 AM
Vxt-24
I have a code flashing 224...It used to flash 206 and was working fine but now has changed to 224 and won't work.
The water level is correct at 75% on the glass sight. I can add or remove water without a problem.
Thanks!!
Old 11-22-14, 12:31 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
The display shows how many gallons of water have been fed, it's not an error display.
The OLDER installation manual below shows a flashing display means it's sensed feeding too much water, or switches set wrong...
http://www.hydrolevel.com/new/pages/...structions.pdf
The newer install sheets don't mention the flashing display
Old 11-22-14, 12:54 PM
Thank you. Now it is working again through no effort on my part. I gaurantee it will drive me nuts.
