combustion air- fieldcontrol CAS-3 Honeywell R8182D
Old 11-29-14, 09:55 AM
Having difficulties locating wiring diagrams for connecting CAS-3 to a honeywellR8182D controller. Any assistance would be appreciated.
Old 11-29-14, 03:14 PM
NJT's Avatar
NJT
NJT is offline
Upvotes Received: 1
Hi Damon, I presume that you are looking for a diagram that is SPECIFIC to your situation.
I don't think you are going to find one...
Can you remove the cover of your R8182D and take a clear well lighted picture so I can see the wiring inside? I know what an 8182 looks like, but I want to see YOURS.
How comfortable are you with 120VAC wiring? Do you understand that you must use ARMORED cable, and NOT the plastic stuff?
Do you know the proper type of connector to use with the particular type of armored cable you will be using? (there are DIFFERENT connectors for the STEEL versus the ALUMINUM armor)
Do you know about the use of the red 'anti-short' bushings when working with armored cable?
How much of the wiring have you completed, if any?
If any, can you show us pictures of what you've done so far?
