How to Trigger Circulator Pump from 2 Sources?
There are 3 heat zones connected to my furnace. The furnace heats the water that runs through the baseboard heating system. We also have a wood burning stove next to the furnace with a water jacket that also heats the water. I BELIEVE the TACO circulator pump does not turn on unless the furnace is running. Can I have the zone valves trigger the circulator pump and not have the furnace kick in if the wood stove has heated the water sufficiently?
