Boiler Help!!!!!
Old 12-08-14, 08:17 AM
T
Boiler Help!!!!!
Hello to all.......I am working on a Peerless Boiler model #64-07-STDG-WS. It has a Baso Pilot Switch #L32GB-1. Here's my issue.......Went on the service call and only the pilot was lit with the gas valve to the "on" position but it would not ignite. So I shut everything down and relighted the pilot. Turned gas valve to on position and I got flame. 10 minutes later boiler turns off and does not restart but pilot will remain lit. If I repeat the process flame will come back on and kick out again. I'm thinking its the Baso Pilot Switch or gas valve. Thoughts?
Old 12-08-14, 09:23 AM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
Hot WATER? or STEAM?
Old 12-08-14, 09:27 AM
T
The boiler is hot water...............
Old 12-08-14, 11:42 AM
T
Anybody? Made a error on Baso Pilot Switch part #. It should read L62GB-1
Old 12-08-14, 12:33 PM
NJT's Avatar
NJT
NJT is offline
Hi Tones... here's the thing... you seem to be a contractor on the job. This is a DIY site and really shouldn't be where you come to get advice.
That said, you need to do some basic troubleshooting. Get out your multimeter and follow the wiring diagram.
Old 12-08-14, 01:13 PM
T
Ok thanks NJ Trooper. The only thing that confuses me is why does it only run for 10 minutes. No wiring diagram available. I did troubleshoot it and its leading me towards the Pilot Switch because the 24 volts dropped out.
