aqua stat l6006A
aqua stat l6006A
Can i put old aqua stat in new indirect water heater or is it advisable to replace it is same model water heater but their aqua stat # is l4080B-1352
If it fits in the well, then why not.
Provided it performs the same functions.
You do run the risk of having an older and perhaps inaccurate device.
It may also be prone to fail earlier due to being used.
Roger, did you end up determining that the indirect is what was causing your pressure problem? And you are replacing it now?
http://www.doityourself.com/forum/bo...-too-high.html
Yes i left the water heater piping out of the loop for a day and everything worked fine put it back in last night same problem again today high psi so i think your assumptions were correct just trying to figure out best replacement for me i would like to keep replacement as simple as possible
