Hot water heating, just installed replacement float no heat pressure.
Hello, I've just installed a new replacement float to my hot water heating system. After that, I've drained out all of the air from my heaters but there's still no pressure (no heat is coming to the radiator). , except the pressure gauge is still showing no pressure. I'd really appreciate it if someone could help me through this problem.
Thank-you
Thank-you
Hi Lena,
The best way to start would be if you could upload a series of pics of your boiler system so we can tell you which valves to turn, etc... we need to see what you're working on in order to properly instruct.
