Sears 387.9255 Aquastat
Hello Everybody,
Yesterday one of the tenants called me because the heat is not shutting off. I went there and the temperature was reading 80 degrees and the thermostat was turned off (digital Thermostat). I tried playing with the thermostats and hit the reset button, the circulator stayed on. I pulled the thermostat of the wall to make sure it was not stuck on and the circulator stayed on. It stayed on for a good 10 -15 minuets then it stopped. I lowered the max setting to 140 degrees and checked the wiring and made sure everything was ok. There is a selector switch on the side of the aquastat with two options, one is auto and the other is manual. It is set to auto. There is a note on the cover stating manual for self gen gas valve which I have no clue to what it means. I compared it to the other boiler and it was set to auto too. I don't know how old the boilers, but it must be really old to have a sears aquastat on it. Do I have a bad auqastat.Is there a direct replacement for the Sears 387.9255?
Thank you,
Thank you,
Can you photo the aquastat? Sears most often used 'branded' controls from other manufacturers.
