No circulation to 2nd floor
Old 01-11-15, 04:29 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
HOORAY!
Keeping it manually open right now so it always flows on any calls
One thing to know... I'm not sure if the Erie are the same as Honeywell in this respect, but...
If you lock the lever in manual on a Honeywell valve, the first time that the thermostat calls for heat on it's own, the valve will UNLOCK out of manual and revert to auto again.
So just in case the Eries are the same (I think they are) you want to turn that thermostat DOWN so it doesn't call for heat.
Old 01-11-15, 05:00 PM
N
Good point. Right now I still have the power head off so that won't be a problem. A programmable stat may be in order for up there. Is there one out there that calls periodically regardless of temperature?
  #83
Old 01-11-15, 05:17 PM
N
On a side note, I rebooted the outdoor reset and it seems to be working better now. Actually reaching target temp now.
  #84
NJT's Avatar
NJT
NJT is offline
Not that I know of...
There used to be a gadget that they sold for wood heated homes that would call thermostat on a time schedule, but I can't find that any more...
  #85
Old 01-11-15, 05:22 PM
N
Is it this
ThermGuard
  #86
Old 01-11-15, 05:23 PM
NJT's Avatar
NJT
NJT is offline
Found it...................................
ThermGuard
  #87
NJT's Avatar
NJT
NJT is offline
You found it too! .................
  #88
Old 01-11-15, 05:31 PM
N
Haha. Might have to pick one up.
  #89
Old 01-12-15, 06:57 AM
N
Found the TACO PC610 as well which I think would plug right into my controller. Problem is, the shortest setting is 4min on, 1hr off. Now I really don't think the pipes would freeze in an hour unless it was brutally cold out, but then again, I didn't think they would freeze in the first place...
Seems like this might not be a bad thing to have in the summer either to get the zones circulating periodically just to keep things working.
What do you think?
  #90
Old 01-12-15, 07:31 AM
NJT's Avatar
NJT
NJT is offline
I believe that board is a 'pump excercise module... and unless a zone valve is open all it will do is run the pump 'dead headed', and no flow to the zones.
  #91
Old 01-12-15, 07:33 AM
N
Hmm, I read on another forum that it would open zone valves and everything would operate as if there was a call for heat. I guess I need to do more investigation.
http://forum.heatinghelp.com/discuss...-card-question
  #92
Old 01-12-15, 08:14 AM
NJT's Avatar
NJT
NJT is offline
I would independently verify that... he said it will also fire the boiler and I don't think that's true...
Write to Taco, they're pretty good about answering questions.
  #93
Old 01-12-15, 08:24 AM
Geochurchi's Avatar
Received 66 Votes on 62 Posts
  #94
Old 01-12-15, 08:32 AM
NJT's Avatar
NJT
NJT is offline
I did... and I see nothing there, nor in the documents for the ZVC-EXP that indicate that the 610 module will open all the zone valves.
The -exp panels BUILT IN pump excercise WILL OPEN zone valves, says that in the manual... so I have no reason to think that the 610 won't follow suit, but it does not explicitly state that in the installation docs.
And none of them say anything about firing the boiler...
  #95
Old 01-12-15, 09:35 AM
N
Ya, I will mail them and see.
  #96
Old 01-13-15, 07:33 AM
N
Taco said the circ will start, all valves will open, and the boiler will fire.
  #97
Old 01-13-15, 08:00 AM
NJT's Avatar
NJT
NJT is offline
Wonder why they don't put that in the install manuals?
Good info to know, thanks!
But now... I wonder... why would a pump excercise module fire the boiler?
Part of the reason for excercise is that the wet rotor pumps have a tendency to 'stick' after sitting over a long period, summer for example... why would a pump excerciser also fire the boiler?
  #98
Old 01-13-15, 09:30 AM
N
Not sure, but it sounds like it acts just as if a thermostat would on a call for heat which is what I want. Might try one, they are relatively cheap at around $40-50 or so.
NJ, if you don't mind me asking, what is your background/profession?
  #99
Old 01-13-15, 11:18 AM
Grady's Avatar
Received 23 Votes on 21 Posts
My guess is the boiler firing is a side effect of the valves opening.
  #100
Old 01-13-15, 12:02 PM
N
That's what I am thinking Grady. The valve opening is making the end switch contact and starting the circ and boiler.
  #101
Old 01-13-15, 01:57 PM
Geochurchi's Avatar
Well, if that's the case the Thermguard would be cheaper,I would think it would be better to try and configure it so that it is connected to the thermostat terminals at the boiler rather than the way the instruction seem to lead.
Just a thought! Geo
PS where in Maine?
  #102
Old 01-13-15, 02:36 PM
NJT's Avatar
NJT
NJT is offline
Yes, I'm sure... but you would think Taco could engineer a way to exercise pumps without running the burners...
  #103
Old 01-13-15, 02:38 PM
NJT's Avatar
NJT
NJT is offline
But then the zone valves would not be open and defeats the purpose of circulating water to prevent freezing.
  #104
Old 01-13-15, 07:49 PM
Grady's Avatar
The few minutes the burner is running isn't going to make a hill of beans worth of difference in the cost of operation. Why not exercise the whole sytem. Every Saturday or Sunday morning in the off season, I turn all of my stats up until I feel hot water returning on all zones. Takes all of maybe 5 minutes.
If you exercise do you just do curls or sit ups? Grrrr....
  #105
Old 01-14-15, 05:40 AM
N
Still torn between the two. Not sure which I will get.
Just a thought! Geo
PS where in Maine?
If I got the ThermGuard I would connect it in the basement at the Taco box instead of at the stat. Don't really want a box hanging below the stat. I am originally from Jackman, now bought a house in North Berwick.
What difference would it make what end of the stat wire it is wired to, whether it be at the stat or at the Taco box?
  #106
Old 01-14-15, 05:44 AM
NJT's Avatar
NJT
NJT is offline
Thermostat terminals at the Taco would be fine.
And that's AFTER the Taco panel... not the same thing.
  #107
Old 01-14-15, 05:55 AM
N
True, that wouldn't work.
What's your background NJ?
  #108
Old 01-14-15, 07:03 AM
NJT's Avatar
NJT
NJT is offline
Pretty much everything.................................................
  #109
Old 01-14-15, 07:14 AM
N
Thanks for the specifics........................................................
  #110
Old 01-14-15, 07:37 AM
NJT's Avatar
NJT
NJT is offline
Check your private messages........................
  #111
Old 01-14-15, 08:29 AM
Geochurchi's Avatar
Just a neater installation than having something stuck on the wall with wires going into the thermostat.
IMHO
Geo
  #112
Old 01-14-15, 08:32 AM
N
IMHO
Geo
That it is, but like NJ mentioned, it would need to be wired on the stat side of the Taco box, not the boiler side.
I am in North Berwick, originally from Jackman. Where are you in NH?
  #113
Old 01-14-15, 08:33 AM
Geochurchi's Avatar
Sorry, onto the thermostat terminals in the Taco controller,just took to much for granit.
Geo
