How to add radiant heat to steam boiler
#41
demand for steam from the other part of the house kept the boiler temperature around 120-140 degrees
#42
Here is some info I found that suggest that they might last up to 20+ years.
Circulator Pump life | Hearth.com Forums Home
You can't make steam at 140F................
With 85F water, it could be run all the time and not overheat the floor.
